Ease of getting Neutral when Stopped
Can you easily get neutral when stopped
  • Total voters
    32
sfcpiet said:
Quentin,
That type of cable has been used for H-D clutches for donkeys years, never had a single issue with these in my 8 years with the marque.  They are a bit stiff to route smoothly though (not only H-D, but also HD, heavy duty!), might have a bit of a problem getting through the bend to the actuating lever.
I've had a longitudinally wound type clutch housing cable on my 3C since 2008 custom made by Motion Pro here in the USA. And yes, it is stiff and requires some larger arcs when routing..but no problem. A little easier clutch pull effort and very little less adjustments needed..it will not compress.
