I got my disks back from Graham Blake. Very quick turn around of 7 days from when I un-bolted them until I bolted them back on. Not bad considering they had to go from Tassie to Queensland and back, and would have spent a few days in the mail system.
The grinding job looks very nice. Good smooth surface with just a hint of cross-hatching from the grinder. Disks still thicker than the minimum allowable so he only took a bee's dick of thickness off them.
I took the bike for a test ride this morning and braking is now as smooth as ... er ... (insert smooth analogy here). It's way better than the lumpy, jerky braking action I had before.
I phoned up Graham to tell him how pleased I am, and he asked me to write him a testimonial, which I will certainly do. He's a bit old school and doesn't have a website or even email, so the testimonial will have to be on paper. I'm not sure how he's going to promote his business without electronic media, but that's his concern.
He grinds the disks on their carriers as an assembly. First he trues up the face of the carrier where it bolts to the wheel, then grinds each face of the disk to exactly align with the carrier, so 6 grinding operations for two disks. He charged $190 for the job. Money well spent as far as I'm concerned.
He explained that he uses a process he calls freeze feather grinding, in which he uses copious amounts of iced water as a coolant to keep the disk at a constant 0 degrees while grinding. He reckons it eliminates any local heat distortion from the grinding process and therefore doesn't induce any residual stresses. I put the dial gauge on the disk when I fitted it up to the wheel, and there's no axial run-out at all. I'm not sure what the "feather" bit refers to, maybe the hatching pattern on the finished surface.
Anyway, if you have original cast-iron disks that are less than perfectly smooth or even slightly mis-aligned, I recommend giving Graham a call on 07 3200 0644. He doesn't always answer the phone because he may be operating a machine. If that's the case, just try again later. He doesn't have voicemail.
Cam
