mauricejota7604
- Victoria Australia
I am in the process of plugging everything back in on my early triple and am going to use most of the original wiring including the mutispade connectors in the headlamp, for those that know them there is a large connector block that has a direct feed from the red wire coming back from the ignition switch there are several looped red wires in this block that feed other circuits.
The other multi spade block has a brown wire coming back from the ignition switch that appears to be the only direct feed, my question is should the brown wire from the switch be a closed circuit once the switch is in the normal on postion or is it only the parking light function on the second switch position.
For the life of me I cannot workout how this terminal block gets power, as this brown feed from the switch is a open circuit in the normal run postion from the ignition switch??
