- Calgary, Alberta, Canada
Not Laverda related, but a question who understand dc circuitry.
Google and AI are dangerous.... Both assume I have more knowledge than I do.
On my 2022 Kawasaki H2 SX SE I have mounted two pairs of high output Denali D2 LED driving lights, and a "Data Dim" controller.
I have all the circuits figured out EXCEPT having the two pairs of driving lights go to highest level of output automatically when I switch the headlight to high beam.
The issue is from the trigger signal from the Kawasaki headlight. I have run a single trigger wire off the high beam. The Denali light controller is expecting to see NO voltage when the high beam is off and 12-14 volts when the high beam switches on. My problem is that the high beam circuit always has running DC voltage of 14.2 volts while the high beam is OFF. Strange, but stranger is that when the high beam is switched ON the high beam circuit has a DC voltage of 39.5 volts. I checked with Kawasaki, this is "normal".
So, I need to add to the single trigger wire from the headlight to the Denali light controller something that blocks, say. everything below 15 volts, to zero, but reduces the 39.5 volts to, say 20 (?) volts or whatever will not fry the Denali light controller. I have gone down the rabbit hole trying to figure out DC op-amp comparators in IC form, but the basic one I found LM3111 has an upper limit of 36 volts. Frankly I am lost. Denali does not seem interested in figuring out the issue in relation to such a low production number motorcycle....
if I knew what I was doing I suspect this should be fairly simple, on the signal trigger wire block to zero everything below say 15 volts, and allow say half of the 39.5 volts to pass through to trigger the full intensity of the LED driving lights when the bike high beam is switched on.
Anyone?
On a Laverda related note, the snow is mostly melted here, I spent today changing oil and brake fluid on all three Laverda triples, firing all three up, and short warm up rides on each of the three. Clutch plates are dragging a bit on one of them which I am sure will be remedied by a longer and harder ride. All three are a bit dusty from winter storage, a good cleaning is in order in the next while. The 79 1200 really barks with the recent full chrome exhaust system from Malcolm Cox, beautifully made, great fit.
Paul LeClair
Anyone?
Paul LeClair
