Eliminating speedo and tach
CDHE
Boulder, Co
Are there any recommendations for plugging the drives when eliminating the cable driven gauges? I was thinking that I would find some old cables and reuse their caps with a slug inserted to plug the holes. No sense in driving those extra gears though.....
You're on the money - I just made a small alu plug that went into a tach cable hex nut with a dab of silicone for the SF tacho drive output. I could cut the entire work drive end of the 5C cam and fit a RH cam end to the LH end - but that would be irreversible wilful destruction!
we have CNC machined blanking covers in stock to close off the tacho drive on both the 750 and triple engines
What are you using to eliminate the cable drives - do you have a link?
I have been vaguely thinking about this - should be possible with a stepper motor/arduino but is there a commercially available option?
Thnx
Speedhut.com
Design your own gauge, can have a single say 4" gauge with GPS Speedo and the Tacho face embedded inside the same face
Can add various light functions like left/right indicator lights, high beam etc
Trick kit
Speedhut gauge 2
If you want to retain your rivets 'budget' GPS speedos could easily used via a cut-and-shut into an ND body for anyone willing to put in the hours. My rivets have all been recycled into beer bottle tops - I used the GPS unit as it came, which cost about AUD$100 - only goes up to 200kph, so a little underpowered for the SFQ ;) - but I can live with that.
Analogue face electronic tacho from a suitable Jap bike can receive the same treatment. Mine is from an '89-91 ZXR250RR Kwaka - also bought cheap. You need something like an Ignitech ignition system to feed the signal. The TCIP4 has a 'number or pulses' setting plus a correction factor menu. It works a treat.
The hardest part would probably be adapting the ND Laverda face to the top of the units, but where there's a will, there's usually a way.
I think the odometer would be the challenge! There should be plenty of room inside the units for a stepper motor and simple electronics. I have form - years ago I bult a speedometer/tachometer displaying on my mobile phone for my SF1. Used the output from the Saches ignition and a simple hall effect/magnet for the speed. The killer for that was developing in Java for the android - I am much better at C for arduinos.
Found some really bad video of the project.
Lots of phone options with this ignition and data logging system as adapting a dash display is probably easy. Based in Sydney as well. One day some bright computer person might develop a site that doesn't involve that cunt of a place, FACEBOOK I MEAN. Nothing ever links, posting involves displays through a tiny slot for one line of writing at a time, you see something you like and 5 minutes later it disappears, you constantly get sent unrelated crap on every involvement, its about as user-unfriendly as you can get. In case you haven't noticed I fucken hate any interacting WITH FACEBOOK but it always seems to occur. It's just complete crap.
years ago we converted a ND Speedo to a stepper motor control, worked out very well
not heard from the owner for 4 years or so but last time I spoke with him he said it was still going well
