AndyW
G'Day folks: I thought it might be best to start a new thread on which we can discuss the merit of different engine tuning techniques and approaches and further deliberate (if necessary) Clem's engine's demise.. the original bearpit of a thread can be left to the bears
After I holed a piston in a 1070 Mini Cooper S on the M1 many moons ago I rebuilt the (modified) motor and took the car for Dyno tuning. I'd set the ignition up with a strobe and balanced the carbs with a primitive though effective vacuum gauge. Carb needles were as recommended by Dave Vizard's Mini Tuning Bible: plug colour looked ok throughout normal driving conditions. Tickover wasn't brill..
Compression was around 12:1 (Longman big valve / ported head)
544 Half Race (rally?) cam
twin 1 1/2 SU carbs.
Guy on the dyno said the mixture was WAY too weak.. took the needles out and filed them away to almost nothing... He wasn't interested to see the timing marks for the ignition.. simply slackened off the distributor (having checked points gap etc) and, at high tickover (2000 rpm) from a fully retarded position simply rotated the distributor to advance the spark until the revs stopped climbing. He then backed it a little to see (or hear) that the revs fell a little and then returned it to the beginning of the peak rev point and tightened the distributor into position. He told me at the time that he was tuning the ignition to suit the fuel. The Dyno result was one of the best they'd seen for a while. Difference on the road was amazing.. much more tractable and as if someone had fitted a turbo too.. Oddly enough the fuel economy improved too (from 16mpg to almost 20
The dyno operator was Harry Ratcliffe.. probably the best Dyno tuner in the North of England in the 60s thru 80s... Ever since then I've tuned my engines the same way and haven't holed a piston since..
So.. I'm wondering if modern (crappy) fuels require a more retarded ignition setting than the rotor scribe marks on our bikes would indicate. My T160 (still in the UK) was designed for 5* fuel and runs horribly on unleaded at the standard timing settings.. I've backed off the ignition a tad and it runs fine if a little down on absolute power and top speed. same goes for my 850 Guzzi..
Anyone else tune their ignitions by ear?
