750TT
- Canary Islands
Hi.
I look for these parts for my exhaust 3-1...1200TS
750TT said:Hi.
Hi Paul.Paul Marx said:Not sue that's important enough with a non standard 3/1.
Tube diameter might be though.
Can the tubes be taken out of the collector?
I was looking for something specific that would prevent me from doing that.Dellortoman said:With non-removeable headers, you'll need split rings to go inside the finned collars. You'll probably have to open up the bore of the collars to go over the ends of the headers and machine a recess for the split rings.
phil37 said:The 500's and some SOHC 750's used the half rings and recessed flanges and factory 3 into one's. Try Slaters in the UK - Regards - Phil
Paul Marx said:Early 750s have 35mm tubes, the 500 is 40mm and I seem to remember the factory 3/1 being 40mm as well.
As long as you've access to a lathe, anything collar be modified.
750TT said:I was looking for something specific that would prevent me from doing that. (using half-rings)
Piet,Nothing in the inbox or spam.sfcpiet said:Santi,
Please check your e-mail inbox, and maybe your spam folder, I've sent you the info you requested.
