As I am dealing w/ an aluminum block & head I always tighten nuts to studs one handed w/ a socket wrench. Don't want to overtighten. I give it a snug turn.
Now I have taken screws out before w/ aluminum flakes. Threads are wearing out. Then I clean out the cavity as best I can. One of the Valve adjustment Caps had to be re threaded! I'll try a quarter turn more.
Tach Cable falls out. Tried re routing going over on top of motor mount on frame. Made an S turn. Worked Ok for a while. Now it falls out again. There are washers on the bottom of the worm under the Cam cover. How many can you put in there? & would this cure it? I always thought the new Tach cables I bought were short...
