When I bought my Jota 26 or so years ago, it came with a cable clutch assembly. I hated it from the first moment until now. The cable got longer and longer the hoter the engine got, there was a constantly changing release point of the clutch which you tried to compensate with that little adjuster wheel. Then you parked the bike, forgott to relax the system again and when you came back, the clutch cable had snapped. Great!
I changed everything to hydraulics once I got hold of a complete set. Since then, I only got stranded at the road side due to a leaking slave cylinder ones. Changed the O-Ring (which was in my wallet), pushed the bike to the next gas-station and got rid of the air in the system within 10 minutes. On one meeting, the ball in the slave-cylinder had given up. Cover off, removed the remainders of the old ball, put a new one in with lots of grease and put the cover back on. roughly 5 Minutes on the 1000 SFC.
Oh - one time, the mechanism welded itself together on the Jota and the overheated ball bearing in the slave piston drilled a hole into the piston (a common fault as a reslut of a dyno-session...). Asked a local guy if he could drill out that hole, cut a thread into it and glue a screw from the back side into it so its oil-tight. Done in 5 minutes, re-installed on a green-field, bleeded the sucker and off I went. I still have that piston, but exchanged it at home against a brand new one...
How many cables have people exchanged in 26 years of ownership? I have been to several Laverda-meetings and on tour with several other Laverda-riders. A broken clutch-cable road-side repair was always part of it. None of the hydraulic clutches ever broke during the meetings.
I love the hydraulic clutch system for 2 reasons: a) it does not change the actuation point and b) in combination with a 13mm pump, it is soooo much lighter while still precise.
