Fiamm horn relay
  • Thread starter Thread starter John lord
  • Start date Start date
J
John lord
Guest
Any one know of a surplier  of horn relays for the 750 with its twin fiamms , that fits in the original space , and works , just asking cheers folks
12V 30A automotive relays are all pretty much the same size. If you don't have much space, just get a simple one without built in fuse. Should be available at any electronics or car accessory shop. If you buy on-line, get it from a supplier in your country (UK?) as international shipping still appears to be somewhat limited.
12v30A , but how many pins and they dont work with the Fiamms , or i cant get it to work , either one horn or the other but not both , and as for putting it in the headlamp , are you kidding wiring extentions and even less space , than its origanal position , and thats a crap spot at that , single horn conversion, might be the answer , and easier ,
I have twin Fiamms on my SF2.
Relay is in the headlight.
Crap 4 pin relay from an auto supplier.
And I use my horns a lot, I'm French.
I definitely like twin Fiamms - Could buy them for $32 a pair from Canadian Tire at one time with the 30 Amp relay.
Point them at the asphalt about 10Ft in front of you - Believe me once honked Everybody will Hear You.
Biggest problem with Fiamms is when you wash the bike or drive in rain - Water will get into the Electro Magnetic Cone and cause rust - Freezing the horn - Just hit them with hammer and spray with Rust Check.
Excuse the Engine - Little maintenance there on my 70 SF0.
Gotta say Dual Fiamm Horns saved my life once or twice.
Sometimes I post sober - HIC  ;o)
Yep sorted , car shop sorted it out and got one for me , cheers lads ,
