Final Drive Chain
I've bought two bikes that had no spring clip on the connecting link. The first one I actually rode home before discovering it. The second one I bought a couple of months ago but hadn't ridden as it needed some fixing up. I only noticed the missing clip last weekend while I was preparing it for its roadworthy inspection.
What is it with dopey owners that don't know how to put them on properly? It's not rocket science.
Cam, if they were O ring chains there is a simple explanation.
Firstly there is a fundamental design fault with 99% of spring clips produced, and
secondly on O ring chains there is a little trick that keeps them in place.
In O ring chain it is the force fit of the plate that is important not a clip or a rivet.
A soft rivet will be easily destroyed by the force needed to dislodge the plate. I will not go
into a long winded dialogue now as I have to dressed  :D :D but I have educated those who
visit my stall at shows and when I have had enough coffee I will sit down and explain all.
With O ring yes it will secure the clip. All you need to do is tap the pins on the clip side with a hammer and the plate will jar its way back against the clip. With O ring the clip is not even needed as the press fit is enough.
With non O ring most of the clips have a basic design fault and I change them for well designed ones on chains I sell. Each one costs me but at least I sleep at nights.
Again too boring to go into on here and why should I help manufacturers for free although I have pointed it out to people who come to shows.
