When i bought my Jota it wouldn't pull the skin off a rice pudding. There were several reasons for that, one of them was 135 mains (Dell carbs). Way oversized. It was running an A/F ratio of around 11:1 at WOT. Went down to 130, 125, 120, Checking A/F ratio on the dyno. Got somewhere near 14:1 with 120 jets. Gain of around 5 RWHP and much cleaner throttle response when opening it up.
Oddly enough, going from 135 to 130 made very little difference - identical A/F trace on the dyno chart. I guess it couldn't flow enough fuel through the needle jet to feed the 135. It probably would have run just the same without any main jets in it at all. This has me wondering whether anyone with bigger main jets than that 130 in Dellorto carbs is actually getting increased flow through the jet orifice.
After a lot of farting around on the dyno, I've zeroed in on carb settings that are almost identical to factory specs (only difference is 120 mains rather than 118). Seems someone knew what they were doing in the factory.
