as long as we're talking about ports...
here's an interesting except from Ian Postlethwaite, Lotus Engineering:
"The design of a modern intake port geometry is a compromise between high speed flow and low speed tumble. The tumble is used at low speed to augment combustion at a time when the flow has generated little turbulence during induction.
As the speed/flow rate increases, the tumble increases and flow coefficients decay. At the higher speed/flow rates the flow has sufficient turbulence, and high tumble is not required. Therefore, a port designed to deliver sufficient tumble at low engine speed will produce a surfeit of tumble at the higher speed/flow condition, at the expense of flow coefficient.
The port for a high performance engine has a steep angle, which endows it with a good flow coefficient. The lack of tumble is not a shortcoming since, in this type of engine, the high engine speed and flow generate the
turbulence required. This type of port would produce relatively poor low speed performance. On the other hand a port for a typical passenger car engine has a much shallower port giving good tumble at low speeds but compromised flow at high speed. The bulk flow structure in the cylinder, described as tumble, is generated by separating the flow from the floor of the port just upstream of the valve. This effectively forces the flow over the top of the valve and produces the tumble. Clearly this does not use the full flow area effectively. If the separation could be reduced at high speed then the port flow capacity would increase.
With this in mind Lotus has developed an innovative port design (figure 2) which has shown improvements in flow coefficient of about 8%. Vortices are generated that draw the flow back towards the port floor and re-energize the boundary layer to offset the flow separation which causes the tumble, the flow attaches more to the inner radius of the port with the modified geometry. The modified geometry shows a similar effect at lower speed and consequently reduces the tumble also. However, the reduction in tumble at low speeds is small and is more than compensated for by the increased flow."
this was pulled from a product brochure i'm certain some of you will find of great interest:
http://www.cd-adapco.com/products/brochures/industry_applications/autoapps.pdf
when you get down to the lotus head you can see how the designer created vortexes with a dropped floor
and while not so easy to do in a small port consider the pic of a S shaped bend in a 727 engine and look at the generators on the short side radius of the bends to keep the boundary layer intact much like they use on upper wing surfaces to avoid stall at slow speed or great angles of attack
michael, i looked at my old sim program from motion. dyno2000. a step below dynomation and engine analyzer pro both of which are full wave action simulators. i definitely need to upgrade
cheers,
scott
