Fork gaiters
Not new, but I definitely have some originals in very good condition. From memory they should be the same for 35mm and 38mm? Maybe not - might only be the upper section that's the same (split clamp/spacer) - someone on here will know.
I think my SF1 had a sort of spring clamp at the fork leg or maybe the gaiter just fitted over the top of the Ceri dust seal?
Prob is I'm in Oz. Could send OS if you can't source closer to home. But if you definitely want new, I'm no good anyway.
Chris,
Have a look here, several Ariete items, probably close to what Laverda used back in the day.
https://www.kickstartershop.de/de/faltenbaelge
HTH
Gerald
I bought some Ariete ones for my 3C.
Much too long, much too wide. Ended up buying some for a Peugeot moped. Perfect.
They do fit a 38mm fork also. At the bottom they simply slide over the slider and are attached with a clamp, at the top there is an aluminum spacer, which I fabricated for the 38mm fork.
I'll let you know if I can't find any closer to home.
