XBCoupeJota
- Race Central - Sydney
mcnicol said:Crispin
Didn't you have to drill some extra holes in the tops of the damper valves too? I was given a hand-drawn diagram (which seems to have disappeared) of how to install my emulators, which did indicate I had to drill a bunch of holes, and I was waiting until I'd found some extra damper valves so if messed up I wouldn't destroy my ride.
Ken
Hi Ken, I didn't drill any holes in the top of the damper valves (not sure where you are referring to). The Gold valves handle compression and not rebound, effectively the complex set of valves in the Ceriani is for rebound. Compression is pretty rudimentary (in both Marzo and Ceriani) and the gold valve takes over this job, so to allow it to work you have to reduce the normal restriction imposed by the hole at the bottom of the damper rod by creating additional holes so the Emulator can take over responsibility for controlling the compression stroke oil flow. To adjust rebound you need to play around with oil viscosity, we recently changed from 5W to 10W to dampen the rebound which was a bit aggressive causing a bit of instability.
JLO's site gives a more graphical example.
http://www.laverdamania.net/suspensiongb.htm
Cheers Crispin
