P.s Another piece of advice from Alto. Basic really, but ...
Filling with oil
The oil level is with the bike vertical and the cap / dipstick resting on the top of the threads. Overfilling will cause leaks and crank case pressure. The 3 ? litres is when the bike is fully dry. You will not (unless you unscrew it) drain the oil cooler, so you won't get 3 ? litres in normally. So check your levels."
P.p.s And this for those pesky balance shafts (Piet may be along soon ... :-*. Actually, I can hear him running fast away in the opposite direction ...
"The engine has a good balance factor and vibration is normally caused by wear on the keys on the crankshaft gears which drive the balancer shaft. We change these keys as part of a service and is very quick and easy (approx 20 - 30 mins) and makes a big difference if, as is common, the key has worn.
Disassembly
? Remove the alternator cover.
? Rock the balancer shaft left and right. If you have movement, the key has worn and needs replacing. (This is only a guide, not a final assessment. The key may have a step worn into it - see below).
? Rock the alternator rotor. Again, if you have movement, the key has worn and needs replacing.
? Remove the alternator rotor (left hand thread) and inspect inside to see if the rotor keyway is worn. This will also cause vibration. We have exchange items with new keyways cut.
? Remove the starter clutch sprag assembly.
? Remove the balancer shaft gear and key. Inspection of the key may show a step. This moves the balancer timing and causes vibes.
Reassembly
? Assemble new key and balancer drive gear. Very important: make sure you align the timing marks on the gear and on it's mating gear on the balancer shaft
? Re-assemble the starter sprag clutch mechanism and spacers.
? Using a new key, re-assemble the alternator rotor.
? Use a NEW alternator crank nut. Old ones come undone, even with Loctite. They are cheap, so no excuses.
? Replace the alternator cover and gasket to finish."
