Simonr501
- Lympne, Kent. UK
Thanks Piet - the 'more to it' was the lever ratio.
SimonR
SimonR
dellortoman said:It would be interesting to know who wrote the article.
clemtog said:be carefull changeing Brembo disc sizes, especially on 500's the Brembo factory (might) have know what they are up to when they designed and fitted the correct size of 260mm discs but fitting units from a 1000/1200 (280mm) with alloy adapter brackets to move the calipers that little bit further away from the fork legs to compensate for the larger diameter may or may not give the best desired results of feel and modulation.The maker does usually know best (not)
