helicopterjim
- near Lone Butte, BC, Canada
First thing is to pill the spark plugs and turn the motor over to find out if the cylinders have fuel in them ....... if they do then you will want to check your oil to see if it is saturated with fuel.If not, just wondering what the effect of leaving taps on really is, and the cure? Can't find a description on the forum.
Not removing the plugs before turning over the motor could lead to one or both cylinders "hydro-locking" and this could cause catastrophic damage. Oil saturated with fuel should not need any explanation as to what could happen or what you should do next.
Jim
