The Coppermine gallery was previously linked to the old (SMF) forum so it uses the same username and password details that you
originally used there. So in the case of Fitz, you need to use that for your username and whatever your SMF password was - usually the same as you're now using unless you changed it after the migration to this new forum.
Please note that for users who changed their
display name after originally registering with the old forum it will not work since it is your original
username that is required.
Any new forum users here (i.e. post 14 Jan) will have to create a separate login to access the Coppermine gallery.
@ Haggis - your SMF username was recorded as Jota981 and that is what Coppermine should be using .... or would have been except that it isn't listed. By any chance did you use a different username before Jota981?
@JoePurple73 - have you registered with the Coppermine gallery?
@Thomas aus LAU - sorry, I don't understand what you mean by
but all personal ordners have gone
In all cases, the ban is a temporary login suspension after 3 unsuccessful login attempts to reduce the risk of ne'er do wells attempting to join the party. It resets after 15mins
Finally(!) I am going to set up an integrated gallery facility linked directly to this forum to avoid the separate login requirement. Just one issue to overcome - importing the existing gallery content
