Gear return spring- 81 Jota
OK, I have now tried two more springs, both of those springs were worse.
When fitted onto the eccentric there was too much gap between the spring and the tab.
Turning the eccentric did not move the pawl arm at all.
I have given up and re-fitted the spring from DAM and will put up with more upward movement than downward movement.
I also discovered a problem with the rear set -set up,the lever on the footpeg was set way too far forward, allowing the lever to basically go as high as it want.
This led to the discovery that the locking sleeve was fucked.
Not happy,I just want to ride the thing.
