blab
- Adelaide South Australia
The marks line up in neutral and it selects all 5 gears, so I am presuming its right.chrisk said:Sounds like your drum is in the wrong position.
I cant weld,all I can do is bolt shit on and hope it works.Grant said:Get the welder out then.
Davo said:What happens when you turn the eccentric 180deg?
They are, I thought that was correct.chrisk said:If marks are at 3:00 and 9:00 maybe you need to be one tooth out.
Minus clearance on down shift,even more clearance on upshift.Davo said:What happens when you turn the eccentric 180deg?
blab said:They are, I thought that was correct.
Grant said:Well, take it to a welder and get a blob of weld tacked on, then file to profile to give the eccentric more operating range.
[/quote
Its a pity this wasnt done when I paid for a 34k rebuild.
blab said:Im trying to get rid of the need to lift the lever over 75mm to up change gears.
Makes riding the thing a pain in the arse.
