carbcleaner
- ny, usa
Hi my name is Andy. I am a new member. Thank you for adding me.
I am working on a Laverda Jota 1000.
EDIT 2- never mind, I found all the gear clearance specifications in the Maintenance Specification" section in the "Green Book". LOL duh...
now WHY would they put it there?!?
I'm used to Moto Guzzi and Ducati manuals, where the specifications you're looking for are almost never in the "Specifications" section of the service manual...
edit- the following shifting problem happens even with the sprocket cover and selector/ratchet mechanism removed.
The symptom the motorcycle is exhibiting is rough shifting 3-4, 4-5 and back down again. Also, sometimes it shifts slightly past 4th going up or down. It does this even with the sprocket cover completely removed. (I got a T-handled tool from Wolfgang in Canada) There is a scratchy or grinding feeling when going from 4-5, kind of like the feeling of lapping a hardened piece of metal on 600 grit sand paper.
I've replaced a few parts, gone over the outer selector mechanism a bunch of times, the shift drum is free and nice, I replaced the shift detent lever and spring (I found out the rollers can be different diameter)...
my next step will be to replace the bearings and maybe gear bushings. Also maybe the forward shaft, as there is a great deal of wear on it where the fifth gear rides.
I am curious if there is a specific manual I can use that has the gear bush to shaft clearance, as well as the gear and shaft axial play and positions relative to the shift forks? I found some nice technical drawings in the 750 manual from this website. Are they similar? The 1000/1200 manual seems to be for the later model with the needle bearing upgrade, and doesnt have much information anyway...
the 5th gear shift fork (brand new from Wolfgang) and the sleeve seem to have a TON of play, (0.75-1mm?) however the sleeve appears perfect– but I'm comparing this to Japanese motorcycles and Guzzi's I've rebuilt in the past.
Thanks!
Thanks!
