One way is to check the lenght of the belts with tailors tape. The original is around 535mm. It is very essentail not to mix different kind of lengths. You can check that the 10 x 495 belt if it is around this. If is around 513mm then the 495 is datum lenght not inner length as should be and...
www.laverdaforum.com
