sfcpiet said:Been thinking about this... not much more power than the original, but a huge weight saving.
My Kubota tractor is an inline triple painted orange. So is my Fiat tractor!!!!Dellortoman said:That's appropriate. An alternator off a tractor.
Are you sure you're not a Guzzi man?![]()
The GPX alternator is an ND, light, easy to fit (well, if you're clever at that sorta thing 8) ) and saves weight on the battery, lose the regulator and all that wiring, and charges well at idle.sfcpiet said:Been thinking about this... not much more power than the original, but a huge weight saving.
Piranha Brother 2 said:The GPX alternator is an ND, light, easy to fit (well, if you're clever at that sorta thing 8) ) and saves weight on the battery, lose the regulator and all that wiring, and charges well at idle.
Chris, were you able to keep your cover original or did you have to get creative?chrisk said:Quentin, what ratio are you using? I'm a little concerned that my Suzuki one my be spinning a little fast at the ratio I have. I'm guestermating that 8000rpm, my alternator will be up around 15000rpm. Maybe I need to increase the pulley dia at the alternator.
'71 SF said:Chris, were you able to keep your cover original or did you have to get creative?
What was the original alternator that the Kuwait bikes had on them? Still looking to reduce weight on the Boba build but keep an electrical system for sort of legal street operations 8) but get rid of as much lead as possible.
Clay
sfcpiet said:Fuck, NO!
sfcpiet said:Clay,
Not all Kuwait bikes had the alternator, my own Kuwait GTL has the normal Bosch DC generator. Daihatsu uses a nice little 40A alternator on their small cars, very popular within the classic brit car fraternity because of it's small build and light weight. Available quite cheaply on the aftermarket.
"Sounds like you are brushing up on your Aussie lingo, before the trip."
Chris, you drongo, the fuckin' tractor alternator was my fuckin' idea, that's another fuckin' beer you fuckin' owe me...
Howzat for a start?
I'll try and post pics of my alternator conversion. Only mod was to slightly bevel the inside front edge of the cover (invisible). it's a powerful ND unit. Most of the work went into making little stainless covers to allow air but not water to enter, being in a nice line to the front wheel!'71 SF said:Chris, were you able to keep your cover original or did you have to get creative?
Clay
chrisk said:Very good. now have look in tech and sort out my current problem. I'll buy you another beer, you'll be pissed all week at this rate!
sfcpiet said:Fuck off!
Gettin' better?
