Dellortoman
- Tasmania, Australia
Hi Dan
With a bike that may have been "tuned" by a previous owner, there's a fair chance that someone has changed the jetting. I wouldn't mind betting that it's over-jetted. My suggestion would be to return the carbs to standard spec for your bike. Stock settings for main jets, pilot jets, slides, needles, etc. The standard settings may not be quite right depending on the fuel you have access to, but it's a good starting point to work from. To get it perfect, you should take it to someone with a dynamometer and exhaust gas analyser.
Before you start messing with carbs though, make sure ignition timing and valve clearances are properly set. Also a good idea to check cam timing. You never know what some previous owner may have done (my Jota had the wrong cam sprockets when I bought it - cam timing was way off).
Standard settings for RGS carbs (from factory workshop manual) are:
Dellorto PHF32 DD (x 2, right and centre)
Dellorto PHF32 DS (x 1, left)
Main jet - 108
Idle jet - 65
Needle - K1 2nd notch
Needle jet - 265AB
Slide - 60/6
Mixture screw - 1.5 turns open
Throttle pump jet - 35
Throttle pump capacity - 6.5-7.0 cc in 20 pump cycles
Air filter - replaceable paper element
If you don't have a RGS workshop manual, PM me with your email address and I'll email you a pdf version (43 MB - too big to attach here). I can also send you a Dellorto manual.
Cam
Main jet - 108
Idle jet - 65
Needle jet - 265AB
Slide - 60/6
Cam
