Rob
- Midlands, UK
Dan - the reason I was a bit tetchy is that Piet was closely involved in the development & testing of the DMC...he's also got loads of valuable experience!
OK - sounds like you have original Nippon Denso (ND) coils fitted. When you were testing secondary resistance, was this with the plug caps in situ? If so, do it again without the plug caps screwed on to the leads. Measuring between the lead (push a nail or similar in the end) and primary negative wire (black) should give 8.3-8.5 kohm. If the end of the HT lead is well and truly mashed, snip 5 or 10 mm off. Should be enough length if this hasn't been done before.
Plug caps need to be suppressed type (5kohm) - they deteriorate with age, heat and vibration so well worth replacing.
ND coils are very reliable and I would be surprised if they are faulty. The HT cable can be removed but it is a major PITA to do successfully because they are bonded in. If you need to, you'd be better off getting some TEK KP03 or MP06 off eBay plus new copper HT lead- fitted to lots of Jap machinery including Kawasaki 250 / 500 or Honda VF750. They are direct replacements. Or given you're in Canada - email or call Wolfgang Haerter laverda@lightspeed.ca Columbia Car & Cycle, 357 Shakespeare Road Nakusp, BC, V0G 1R1 Ph./Fax : 250-265-4502. He's away 9-17 Aug but could quickly provide anything you need.
The supporting bracket is very prone to fracture. Not particularly relevant to no sparking.
BTW - primary resistance is 4 ohm
Finally, when you were testing for a spark, please tell me that you had all three leads with a plug in and earthed, not just one plug being swapped from lead to lead?
