Goisern Classic hill climb 2025
The uphill track in Bad Goisern is 7km long. There are two runs, which you should complete in the same time as possible. The smaller the time difference, the more likely you are to win. That wasn't easy, as the first run was on a wet track and very slippery asphalt, while the second run was on a nearly dry track, with only the hairpin bends and trough the forest still wet. I was much faster in the second run. Ciao, Gert
But as it was a ‘regularity’ run possibly easier to match the times on a smaller machine as it’s likely to be virtually flat out whatever the conditions.
