Grinding Gears
Vince
I learned very early on not to have my 3c rev above idle when selecting 1st from neutral or you get horrible grinding noises. Is this typical? I saw a post elsewhere about clutchless shifts being fine on Laverdas, done it when I have broken a clutch cable to get somewhere to fit another but it's never been a thing on my Laverda. Dirtbikes get cluchless shifts all the time but I just don't like abusing the 3c. Does anyone do differently? Just curious.
N-1 let it warm up for 30 seconds first.
Otherwise, while moving, change gears whenever you see fit. Clutchless is fine as long as you unload the trans first.
Like a roadranger… right Chris?
If you blip the throttle before pulling the clutch in, the gears will spin up, making selection of first, at rest, a noisier affair.
It's kinda the opposite of "double-declutching" in a car, for those old enough to remember doing that.
Leave engine at tickover, pull clutch in and select first.
If it makes a noise you have clutch drag. Adjust cable.
Or don bigger boots.
Correct. Bit of pressure on the shifter and back off the power and out she pops.
