Handgrips How observant are you?
telecasterguru
Sydney Australia
I was looking over my newly arrived RGS this morning and low and behold I found that the hand grips on the bike are different. Not very observant am I when in the lustful buying frenzy.
Now I need to get them both the same. Which grips should be on the RGS?
Pictures are below of the two grips currently on the bike.
Frank
Don't care what grips I select, they all wear out. I liked the Oakley's, great design but terrible compound and turned to gum. I always add a rubber strip to the throttle grip to egg shape them then wrap the throttle grip with electrical tape - 1/4 turn with a cable Tommaselli throttle control - Wowa!
The right one is the right one Frank.
And a pain on your nick with your wrist for the throttle
The left hand clutch grip can be round but the right hand throttle grip has to be Egg Shaped.
All you need is good solid rubber grips that feels comfortable don't slip, don't gum up and don't disintegrate and I highly recommend an Egg Shaped throttle grip as it has less tenancy to slip through your palm.
Just how strong are them throttle springs you're using - Personally I would not use that Rivet Counter OEM throttle grip when my life depends on it unless I modified it.
Wanna race? Grip design is important.
Don't think that factory OEM spec's is religion; it's just a mean - It's all up to you and that's what I like about the Breganzie theorem regarding motorcycling  - Right down to the throttle grip.
A few weeks back I noticed I had a black brake lever and a polished clutch lever, got the later powdercoated and now it's lovely and balanced.
I got mine satin black at Brookvale Powder Coating for $20.You would be luck this close to the holidays though
The local gourmet cafe in McMahons Point, under the Harbour bridge used to do a Scotch egg meatloaf roll, with a Chutney Glaze. Hard to only buy one slice.
These are without question the best grips I've ever used.
http://randakks.com/collections/grips/products/randakks-amazing-grips
