okay, I flipped the heads over and took some measurements, it is not cold here, +30C today.
Early head is now a 75 head that we have welded but not machined yet, the original 77 head shown below is now wrapped up in gladwrap ready to install.
I used two of the mandrels that I made for my spark plug fixture, machined threads on chromed ground bar so I know they are straight.
Use these to clock up the angle of my milling machine head when machining new spark plug holes.
First photo is now of the 75 head, no cutouts around the area where the spark plug spanner goes through, on the left hand rail.
Measuring the right hand side between the mandrel and the edge of the rail I get 6.76mm gap.
this is the same RGS head, on this head I get 6.87mm gap to right hand side, opposite to where the cutouts are, right hand rail
there are a number of detail changes between the two heads, that is very obvious and I'd say the 120 head is a lot better product
the above measurement only checks the position of the spark plugs in one plane, when I get a chance I'll clock both heads on the milling machine and see if the spark plug angle has changed
would presume the 120 head is steeper as the inlet valves are larger hence would need to move the base of the spark plug hole away from the spark plug
maybe
