the same applies to triples, I had a lump of gasket hit me in the right leg at high speed and very high load, two people and camping gear, and I was going up hill on a French motorway, when pretty much full throttle was needed to maintain 100MPH, and she blew, oil everywhere and a two pot motor. Happenned on the hottest day on record and the Sunday of the ascension weekend, possibly the busiest day of the year traffic wise, recovery took a very long time, no water after the first 30 mins, very unpleasant. The biggest mistake I made that day was not riding the bike off the motorway, because when I eventually got recovered it was by a very small Fiat van, and we unloaded the bike as far as possible, and that included Andrea as well, I then followed the van to a small petrol station where there were comfort facilities and awaited a proper truck to take us to Calais
I had drawn, programmed and made, solid copper gasket's well known to a lot on here, I have sold a lot, and on my own engines, after a very intesive week of develeopment, removing and stripping the motor four times, I have never had a failure, plus on several that I know about, and at one time worked on, plus odd people who come up to me on occasions and say "hi, I have got one of your gaskets fitted" Cutting the flame ring to gain clearance for the four O rings is MADNESS, (better off with no O rings and the old style gasket) that is why I did it, and I still use them, its worse on a 1200 as there is no upstanding liner spigot which engages on the recess in the head as on 1000's, but both gaskets are identical 1000 and 1200, I also machine the top if the block flat so as the gasket face and liner are the same plane (not easy on a 1000, but still doable for a skilled machinist) not 20 thou lower as factory spec in order to achieve a small amount of "backing" effect retaining the gasket, they (moto Laverda) must have known all along that this is a week spot, this changes the compression ratio a tad and in some cases valve to piston clearance (never heard of a clash yet) and has the effect of making the timing chain look a little worn, it could be compensated for by making an aluminium base gasket 20 thou thicker, but never had to, so didn't bother, I don't care about any of that, my gaskets stay in place.
