FlyingApe
- Loch Lomond, Scotland
1) I have heard it said that when new head gaskets are stored, the copper head sealing ring hardens with time ( in the same way copper work hardens).
So, if I have an immaculate unused head gasket that's about 25 years old, should I scrap it, or use it? ( and yes it is the rounded end version)
2) The workshop manuals state you can re-use a head gasket. I am very reluctant to do this, but what do you think?
3) RGS Torque settings. Laverda's workshop manual states 32ft lb for CH and 28 ft lb for outer camshaft nuts. The green book states 27ft lb and 20 ft lb respectively.
What should I be using?
If it makes a difference, I am running 1200cc and high comp pistons with Mikuni flat slides. Hoping for 100bhp+ once set up.
Thank you
Thank you
