Ernesto
- Hamburg, Germany
Are you sure it's a 750S?
Grimeca brakes.
can I spot silicone blocking the oil bearing cylinder studs?
Check check Double check!third picture, with bore centred in frame of photo, bottom left and bottom right studs look full of something black, not oil surely, if so it must be bloody thick gooey sticky stuff to be still stopping there by capillary action!
Pretty much the same as what I’m doing, I’m going to do the clutch rubbers as well.Just got home from visiting Gijs this morning, I left my head there
His verdict; bad exhaust valve and the rockerarm needs replacement, other valveguides are ok. Did some polishing on the camshaft.
On his advice two hardened valveseats for the ex side wille be placed and two new exhaust valves. Also reworking valve guides for seals on the inlet side.
Bores and pistons (original) still within margins, oke for normal use.
In about two weeks I can neatly put it all together, for now I'll put new rubbers in the clutch housing and check the primary side. Also reinstall the cylinder block and Pistons and clean all the oil channels.
keep you posted, thanks for your thoughts so far.
