Franc
- UK - Midlands
Have a long list of things I’m doing on the 750 SF, largely minor annoyances but today I got round to the clutch which I found very heavy. I’d already convinced myself that the cut in the casing and extended arm was the way forward. But having previously read what others have said about old cables and dismissed it because they look - outer is good and the bit of inner at the lever end looks shiny! But Actually disconnected to find the Inner coated in a sticky toffee paste - Presumably old grease and dried CRC residue. Rigged up a mini funnel sealed with tape and blew through with brake cleaner solvent left for a while and repeated. So much gunge! Gave it an hour and flushed with ptfe lubricant.
Reassembled and it’s a whole different clutch, so whoever said check your cables. on the old post I read, it’s true, couldn’t imagine it would make that big a difference. Done the same routine with throttle, front brake and the short rear.
I’m assuming the ptfe lubricant won’t go sticky but if it’s a six monthly maintenance job for an hour probably worth it. with the effort previously needed it has probably weakened the ends so should I replace anyway. Any recommendations on new cables? I’ve made cables up before From the Venhill kit but is ready made better in this case?
Franc
S
Franc
S
