jdugen said:its time to unpack a weeks worth of smelly undies and get them in the washer.
sfcpiet said:Yes Clem,
The factory specified a C3 bearing. But that has nothing to do with the fit in the housing or on the shaft. Simply denotes the bearing has increased internal clearance, ie, between inner and outer race.
If the crank runs true to within 0.02mm or so, you could get away with a standard clearance bearing.
jdugen said:Just a quick update. Bearing fitted, all is as peaceful and quiet as any Lav is going to be. Fitted an SKF as original, a ?12 bearing that managed to spoil a really good holiday, (grumble, whinge).
I could go on to say, why? Why balance a rotor so far away from the main casings? The Japs just bolted the starter clutch to the back of the rotor, would have saved about 2 -3 inches of overhang and given plenty clearance for taking R/H corners.
As my brother would say, 'It's Italian, what do you expect?'
