Lyndoneil
- Towcester uk
Seriously worried here, I rebuilt my 500, new cams, rebuilt and ground to S1 spec, new cam chain, and tensioner, rebored cylinders to 522cc, high compression JE pistons fitted, measured the piston ring gap and filed to perfection, new valve seals, replaced faulty cam followers, , Saches ignition fitted, lapped in the valves as best I could, dodgy cam blocks timeserted, new cam bearings, new coils, replaced all jets and needles in carbs, set up valve clearences to perfection, etc etc, to much to list, I'm on my 4th strip down now, evey time I retouque the head I'm waiting for the monkey metal to give out.
After asking a question about the tensioner blade fitment, and as it turned out I got some good advice, I find that the prescribed solution is to put it in a vice and hit it with a hammer to a suitable undisclosed amount.
Jez! Clearly I'm a Ducati owner and shouldn't have strayed.
