some progress being made, was out and about yesterday in the Chevy truck getting race tyres changed ready for Phillip Island next weekend and called in to see a company that specializes in all form of rubber mouldings etc
Had with me a brand new unused tensioner blade, couple of broken ones and a new length of spring steel
First they cut off a sliver of the mould on the new blade and tested it to see what it is, they said it is just Nitrile Rubber which is a bit surprising
Then said they can do it and gave me a price of around $1,000 for the mould so have decided to go ahead with them, no idea on the cost of each item yet, find out next week
$1k is nothing compared to the engine damage I am getting from breaking these fucking cam chain tensioner blades all the time
Back home and set up and machined 20 lengths of spring steel, is a good thing I have plenty of solid carbide drills and end mills as this spring steel just eats normal cutters but they are all done ready to drop off
Looked at the positioning of the end of a standard blade installed in an empty engine and decided to make these custom blades 65mm longer so the end will be 15mm past the center line of the cam chain sprocket on the crank shaft
To me that makes sense and if it does not work then no issue to shorten them if I have to
20220825_171136[1]
20220825_143505[1] by
Red Cawte, on Flickr
