rocketonarail
- Gloucestershire
I`ve always had this thing about keeping a bike in standard spec , as the factory intended .
Obviously this is not possible in the strictest sense , if you`re going to use it then as soon as you replace the battery ,change the fork oil or put new pads in you are altering it , but I like to keep to the spirit of originality as far as possible .
I was never inclined to try to improve or upgrade things like chassis parts or brakes , mainly due to the belief that if the brakes felt a bit wooden , or the bike tended to weave a little when leant over in some corners or had a tendency to run on in others , then that was just the way it was , that was the way a Laverda behaved ......the authentic 1970`s experience if you like , to try to make changes that would dilute or nullify that raw original riding experience would be missing the point.....
But it did make me think about how original is original ......below is a pic of the Mirage on it`s fortieth birthday ( I know the indicators are missing but that was just a temporary thing...pretend they`re there )...
It may appear to be fairly standard but the only original parts that remain as they left the factory are basically....
Front mudguard
Headlamp lens and bulb holder
Handlebars
Ignition key
One front brake caliper body
Oil cooler
Oil filter
Oil pump
Starter motor
Starter gear
Front brake hydraulic junction
Rectifier
Fuse holder
Cam cover
Engine cases
Crankcase breather pipe and ball
Cam chain pedestal
Clutch actuating mechanism
Fuel lines
Petrol taps
Gear clusters
Foot rests
Gear lever
Rear brake lever
Rear mudguard
Rear wheel
Rear disc
Rear brake caliper body
Rear brake hydraulic reservoir and master cylinder
Rear grab rail
Rear light bracket
Rear chain adjusters
Tail piece undertray
And I think that`s about it....however I don`t claim to be perfect and may have missed some parts that have remained original......if you can think of what they might be then let me know and I`ll try to prove you wrong.....( you`ll only have my word for it so you`ll just have to trust me...)...
Front mudguard
Handlebars
Ignition key
Oil cooler
Oil filter
Oil pump
Starter motor
Starter gear
Rectifier
Fuse holder
Cam cover
Engine cases
Cam chain pedestal
Fuel lines
Petrol taps
Gear clusters
Foot rests
Gear lever
Rear brake lever
Rear mudguard
Rear wheel
Rear disc
Rear grab rail
Rear light bracket
