He started by mentioning that when he pumped grease into the swingarm, it came out of the ends, asking if it was normal.Don't understand what you are getting at Paul.
Grease coming out is normal. It should come out until as Legs ( come Mistinguetti have bronze bushes Paul, so wondering how much grease getting out is to much? or how to minimize this flow? The reason i am looking at this is i noticed play at the swingarm (maybe +-1.5 mm at its end) and i pumped grease to reduce it and that worked well. Problem is after maybe 200km i have again the same amount of play and a lot of grease all around. Any suggestion?
In a nutshell, your bushings are knackered. Whoever owned/rode/maintained the bike up to this point has neglected to lube the bushes, now they and/or the spindle upon which the swingarm pivots is/are worn out... simple really.i have bronze bushes Paul, so wondering how much grease getting out is to much? or how to minimize this flow? The reason i am looking at this is i noticed play at the swingarm (maybe +-1.5 mm at its end) and i pumped grease to reduce it and that worked well. Problem is after maybe 200km i have again the same amount of play and a lot of grease all around. Any suggestion?
Yes, you need to fill your grease gun with araldite if you want it to fill up the gap and stay put.Taking up the play with grease can only be a temporary measure, just a little bit of use/movement through the pivot will quickly squash any grease out of a larger gap.
I've had a bearing outer loose. It needed Loctite to make it stay put.Just fitted new needle rollers to the Jotas arm and now find that the bush is tight in the bearing on chain end of arm. Swap bushes between ends and the problem stays with the chain end of the arm. The housing bore was visually looking good, so my guess before getting bearing out again is that the housing has become a little oval so bearing distorts. The old bearings weren’t bad, nor the bushes, just replaced as had everything painted. anyone encountered ovalster in the swing arm? Any tips on overcoming the problem? Will probably use as is until winter, bearing is notchy so should be okay for a while.
