Ha! I'm sure Paul will see the humour in that responseIt should make a circuit when pressure is applied to the brake lever.
If it's connected and full of fluid and not working ... you'll have to take the f...ing thing off again anyway.Looks like I'm going to have to take the f....ing thing off again.
Looks like it, only it's one of those jobs with consequences.If it's connected and full of fluid and not working ... you'll have to take the f...ing thing off again anyway.![]()
Thanks Gerald, will give it a try.Paul,
you have a bike to compare, right? the brake light switch works on the SF2, but not on the 3C.
Hook up your multimeter to the SF2, the restistance setting should display some value when the brake lever is pulled.
Repeat the exercise on the 3C and see what you got. If the reading doesn't change, your switch has an issue.
Gerald
There's 3 wires. 2 grey ones from the switches and a black live feed.Why not bridge the two wires if it lights the brake light its the switch if it doesn't its the wiring
Thanks.Presuming you have sufficient fluid in the system to develop pressure when you apply the brake lever, then there's no need to remove the switch to test it. It's a simple matter of putting a meter across the spade connectors on the switch. Use the lowest Ohm scale. Some meters have an audible beeper to indicate continuity when the resistance is below a few Ohms, which makes life easier because you don't even have to look at the meter.
Brake not applied - meter reads infinite resistance.
Brake applied - meter reads zero Ohms. Don't worry if it's not exactly zero. Most meters aren't perfectly zeroed.
Thanks, will do as soon as I have a rear brake switch wired in. I've just ordered a Honda one, €5. Will wire it in next week and see what gives.Connect your multimeter on to the two connectors on the switch and have it on ohms. Push the brake pedal. If its an analogue meter you should have a full scale deflection, if its digital it should be zero (or very low) ohms.
I don't understand where your thought process is leading you Paul. The front and rear brake switches are wired in parallel so one will still work without the other switch being present. Testing with a meter is best done with the wiring disconnected anyway. So the entire wiring harness can be in another room for all the difference it'll make.Thanks.
Looks like nothing is going to happen until I wire in a rear brake switch anyway, it's an integral part of the circuit, both switches being on the same circuit.
Ok.I don't understand where your thought process is leading you Paul. The front and rear brake switches are wired in parallel so one will still work without the other switch being present. Testing with a meter is best done with the wiring disconnected anyway. So the entire wiring harness can be in another room for all the difference it'll make.
