Dellortoman
- Tasmania, Australia
Hmm ... OK. I wasn't convinced by your assertion so I did some research. It seems we're both right.Std bolts for calipers are 17mm M10 hex heads (as in not an allen head). The two halves of the calipers are held together by allen head bolts.
It looks as if the early twins and triples with Ceriani forks had their calipers mostly fitted with hex head bolts (although there are a couple in Falloon's book with Allen heads). The Ceriani forks have the calipers fixed to the inside face of the fork lugs, with the bolts passing through the fork lugs and into threaded holes in the caliper.
The Marzocchi forked bikes have the calipers on the outside of the fork lugs, with socket (Allen) heads bolt going through the caliper flange into threads in the fork lugs.
I've had a look online at a bunch of photos of 500 twins (which is what Andy's bike is) and it looks as if they follow the Marzocchi setup, with socket head bolts.
