The Zane is 750S renowned for a tuning glitch at about 3500 rpm.
These are 3D graphs of a stock 750S ignition timing files. If one of you is experienced at reading them, please speak up, 'cos I am Not.
The 2nd one is "normal" view, and the 1st is rotated and tilted so we can see the "back of the ridge".
What really stands out to me is that at the current throttle position (7.36%) the advance curve is at 23degrees at 3500rpm, and is at 39degrees at 4000rpm.
That's a BIG change for 500rpm. I could well imagine an engine hunting on deceleration, and flicking between 23 and 36 degrees, which would cause an engine to glitch and hunt some more???
I am considering editing the map so that the rpm gradients were much more "parrallel", uniform, thus reducing the change in timing in the 3000 rpm to 5000 rpm range to much smaller changes like the rest of the map. I'm a bit worried about creating preignition, but if i'm careful to not actually advance the timing at any given rpm i should be ok? I hope...This exercise is solely to see the impact on the glitch, I'm not worried about improving performance at present.
I'm only just starting with all this, so any opinions, support, learning opportunities, constructive criticism ect gratefully accepted. I have looked at a Ducati 916 map, and it looks uniform and even compared to these.
Regards, Greg
Regards, Greg
