This is correct- they are just bungs- open or closed...or leaking down a bit!You don't need a synchronisation of the choke sliders, you want them to close, hermetically.
sorry, but this is not true. Just like any slider, they are not digital but linearly opening. In Extreme, one could be closed, one half way open and one fully open, which would cause the first cylinder not to fire, the second to fire fine and the third one to fool the plug.This is correct- they are just bungs- open or closed...or leaking down a bit!
Certainly, but I don't run with the choke on. When they're down, they're down.Makes perfect sense that they need to be synced. Otherwise you're getting totally different richening effects in each cylinder - a recipe for crap running and fouled plugs.
You could probably start the engine with the choke to two cylinders disconnected completely. You could probably start it just by squirting fuel in with the pumps.sorry, but this is not true. Just like any slider, they are not digital but linearly opening. In Extreme, one could be closed, one half way open and one fully open, which would cause the first cylinder not to fire, the second to fire fine and the third one to fool the plug.
No Laverda (except maybe at minus 10° Centigrade...) needs full choke on starting (or something else is sett wrongly...) My 1000 SFC f.e. always started best on 2/3 of choke, the Jota on 1/2 open chokes, maybe a bit more (while they were still on Dell'Ortos). Personally, I always start a bike by first pressing the button and then slowly open choke until it barks to live to make sure the plugs do not get fooled.
For a while (until you came along) I ran with two of the plungers disconnected from their cables (retention springs still in place) so as to only operate a single choke when starting and thereby reduce plug fouling. Seemed to work well though that is now the cylinder pulling a bit of oil through,,,Thanks for the input everybody, have set the choke slides up as suggested. Will see in a day or two how she runs.
You should have disconnected all three and just used the accelerator pumps to squirt neat petrol into the bores.For a while (until you came along) I ran with two of the plungers disconnected from their cables (retention springs still in place) so as to only operate a single choke when starting and thereby reduce plug fouling. Seemed to work well though that is now the cylinder pulling a bit of oil through,,,
Where's the problem, Clem? You only need to check/adjust each pair of floats individually. Some people use a fixed guage, I use a steel rule marked at 0.5mm increments. You do of course need a keen eye, a sense of orientation and a little experience with the spring-loaded float valve plungers.I would like to know how a moulded plastic float can be measured (with any degree of accuracy, and conformity accross three units) to + or - 0.1mm
Well - in this case, the floats were 0,6 off (OK - 0,1 out of maximum tolerance, but actually 0,6 out of correct adjustment). it is not a big thing to measure that, especially with the right tools...:Clem, I also wondered how you could ascertain an increment of 0.1mm when dealing with float height. Everything you say above is absolutely true of course, Piet, but doesn't really address the point Clem was making.
