Ignition advance location pin
CDHE
Boulder, Co
Could use some advice on how to safely remove the stop pin so that I can install the rotor that came with my new ignition. Thanks!
Now we're getting somewhere... :rolleyes:
The rotor needs to be removed, the pin can then be knocked out with a pin punch from the rear, easy peasy.
Okay. Pin is out. Here is a pic of the rotor that came with the ignition. In the instructions, it appears that the rotor has a pair of notches. Are these what the photocell reads? The flange on mine is a smooth cylinder. Is this correct?
What type of ignition do you have and where did you buy it? Photo of the electronics box perhaps?
Yes, the magic eye "reads" the 2 notches to produce an ignition impulse for the coils.
The Witt DMC systems I am familiar with and that I helped develop and produce has exactly such a rotor, except it would be made from aluminium anodised either blue or silver, not in yellow zinc plated steel.
Purchased from Wolfgang. Looks like I ordered it July of 2023. Wow. This project has dragged on.
Your Rotor and the Rotor your Ignition needs dosnt match.
