G
Grant
Guest
1978, original (new) loom.
Thanks.
Thanks.
Dellortoman said:I can't see much use for terminal 50 on a bike. Who starts a bike with the key?
Grant said:Ok, I put a multimeter across the terminals on the switch and tried the key in each of the 3 positions:
Key in centre: none of the terminals are live (key can be removed from switch) I guess this is off position.
Key to left: 30 and 16 live (key can be removed from switch) Ignition only on?
Key to right: all 4 terminals are live (key cannot be removed from switch) Ignition and lights on together?
With the key to the right each contact is live to each of the others. I thought they were paired for ignition, paired for lights, not all interconnected??????
Still at a loss to work out which colour wire goes to which terminal....
The Cali diagram seems to be a bit at odds with the Bosch DIN numbersGrant said:Doesn't use terminal 50 though.
Davo said:The Cali diagram seems to be a bit at odds with the Bosch DIN numbers
Terminal 50 to coils via kill switch on that diagram.
15/54 is power in from battery - unfused
30 takes power via fuse to start relay and brake switches
16 takes power via fuse to light switch.
laverdakeith said:I'd say you need a longer clutch cable... That's not Don Cairns old bike is it?
Keith
