Because I'm just a tinkerer and not an expert I thought I'd relate some of the results of tackling a 'miss' I've had for a while on the 1200.
Basically relating to the Ignitech box ... there has been some missing at higher revs. ( > 4000 rpm) and I'd set the ignition as recommended by those in the know to Auto (sensing the coil resistance and dwell etc.) with a dwell addition of ~ 25% and was using dynamic dwell addition of ~ 20%.
The coils are Dynatek minis @ 3 ohms (one dual fire) (which are said to be pretty useless) (might agree) but I've finally found an answer of sorts.
Thinking that I wasn't getting enough dwell (charge time) I was upping the dwell, finally 125% to 150% and it ran like sh*t so came home again and reset the box to only a 10% addition. Voila! It actually ran great.
So, for those with an Ignitech ... AUTO might work well for you.
