Icon sells a steel top section that's a bit longer than the standard alloy bit and I had then fitted when the shocks were rebuilt. I made something similar to Cams gadget but less adjustable to see what effect jacking the rear had problem was I didnt want to weld it on so it was boltable and to avoid any rocking on its mount with its one and only bolting and to allow its fixing bolt and the shock bolt to fit it ended up jacking the rear about 35mm. My first couple of rides around the block were interesting. It steered MUCH faster, too fast for my comfort and the seat was stupid high.
And then I found that Icon bit and that was either 15 or 20mm and that did what I wanted.
The whole point of this tread is my bike lately isn't handing the way it was and not to my liking. It has a distinct hing in the middle feel that wasn't there before, even when I had all those broken spokes in the rear wheel it felt more stable. And I think it started with the harder rear shock spring going in. That's my guess, other suspects are my oddball tyres wearing to where they are causing it or the swingarm bearing are suddenly causing it or my newly spoked rear wheel is causing it. It's not absolutely horrible, it just feels looser than before. Not as confidence-inspiring as it was. So I will fit the softer springs when they arrive and see if that fixes it. If not I will move to the next suspect. Ever change I have made I test and usually, it's for the better, this has me stumped as to why it's suddenly happening. What's even odder is its intermediate, bike feels good for a while on a ride and then it starts tram tracking or moving around slightly with no input from me. Hing in the middle, I cannot detect any play except that tiny bit from the now replaced wheel bearings.
