chris78jota
- England
The brakes on the tiddlers were fairly small by modern standards and started with single-sided drums which were held onto the right-hand fork leg by a through-bolt which passed through the drum and backplate - a basic steel drum on the 75, or an alloy finned version on the 100. These evolved into a full width aluminium brake on the Sport Lusso 100. The racers originally had something that looked like a larger-finned version of the 100, then a lovely full width brake.
Because I've nothing better to do with my time
, and can't find a race brake, I've tried to improve a 100cc finned alloy brake as best I (and my mate the gifted engineer) can. The through-bolt can be a sloppy fit in the backplate and fork leg, so we've extended the unthreaded portion of its shaft and put a top-hat bush into the brake plate for a snug fit. The brake pivot has been bronze bushed ; it came with about 25thou clearance from the factory.
Classic Brake services relined the brake and skimmed the linings to a close fit.
In order to increase the finning and cooling, my engineer first skimmed the fins off the hub, then shrank a HE30 aluminium ring onto it. Five deep cooling fins were cut into it, as per the early single-sided race drum.
It'll be some time before I can try it out, but I'm hoping the alterations we've made will have maximised whatever potential the little brake has.
