R
richtea
Guest
Hello all good sparkies,
I have the old 'indicators flash too fast' problem. I had a quick search but couldn't see a definitive answer (probably because there isn't one!).
Maybe someone recognises the type of flasher unit, and can suggest the best solution?
Bike:
SFC1000 (and running v sweetly. Bloody miracle after 2.5 years, but that's another story...)
Flasher unit:
12V 42W stamped with 35020 (see images)
3 wires: black, white/black & green (seems to match the wiring diagram if the 'green' wire is really faded blue)
Bulbs:
All 12V 21W, all working well
Console indicator bulbs:
Both working
Both pairs flash at the same consistently high speed, at around 120 times a minute - fast enough to potentially annoy a grumpy old MOT tester.
The consistency suggests it not the wiring, and anyway poor wiring = slower indicators, not faster surely? Both those suggest the flasher unit might be the culprit.
Is the tin can one that can be opened and the flash rate adjusted?
Or maybe its just a bin it + replace?
Thanks in advance...
Bike:
Flasher unit:
Bulbs:
Both working
