There's a small flaw in your logic. If it drops back to two cylinders it can't be the double coil, otherwise you'd only be left with one cylinder straight off. Not two then one, because the two plugs are wired in series. If the coil fails then you lose both L and R spark plugs at the same time.Since the pattern of the miss is to drop back to two and then one cylinder, I'm starting to think the double coil might be a candidate for replacement.
Look at things that are common to all cylinders. Carb jetting, fuel quality, fuel starvation from a blocked tank breather, etc ...
Hi Dellortoman,There's a small flaw in your logic. If it drops back to two cylinders it can't be the double coil, otherwise you'd only be left with one cylinder straight off. Not two then one, because the two plugs are wired in series. If the coil fails then you lose both L and R spark plugs at the same time.
When my jota had an ignition failure on the centre cylinder, it reminded me of my old 1967 Triumph Bonneville. It went into parallel twin mode with a very similar exhaust note to the old Bonnie. Had about the same power too.
Edit: Having a bit of a head scratch on this. Having it fail in stages (first one cylinder then two) is a bit strange. Given that your bike has two independent ignition systems, it would require an intermittent failure in both systems, but not at the same time (otherwise you'd lose all 3 cylinders). That leads me to the conclusion that it's not an ignition problem, unless you have two dodgy spark plugs.
Likewise, it has 3 independent carbies. So if the jetting is OK, you'd need a problem in two carbs to cause your issues. That's not so unlikely. If you've had a shitty load of fuel, there could be gunk in the carbs.
interesting thing about the dual coil, lets call it the energy, it runs down lets say No 1 spark plug lead, jumps from the electrode across to the spark plug body, travels across the engine to No 3 spark plug area, jumps from the head itself to the electrode, travels back up the spark plug lead to the coil and completes the circuitHowever, on top of that problem, the HT wire on one side of the double coil had come free of its electrode and was rattling around loose in its hole. As I figure it, when the dodgy coil's power weakened after a few kms, there was insufficient oomph from the coil to jump electrode to loose HT wire. Then as the coil weakened further, it would eventually fail altogether on both sides, leaving only nr 2 firing. When the coil would recover after being shut down for a few kms, the cycle would begin again.
I agree Red. You can't lose spark on just one plug in that system. It's both plugs working or both not working.interesting thing about the dual coil, lets call it the energy, it runs down lets say No 1 spark plug lead, jumps from the electrode across to the spark plug body, travels across the engine to No 3 spark plug area, jumps from the head itself to the electrode, travels back up the spark plug lead to the coil and completes the circuit
if you interrupt any part of that circuit you will lose both cylinders either totally or intermittently
How about this explanation... the breakdown caused voltage drop and consequent variable spark.I agree Red. You can't lose spark on just one plug in that system. It's both plugs working or both not working.
However, I can imagine a (theoretical) failure mode that would appear as though only one cylinder has failed. If a fault in a cable is making and breaking the circuit due to engine vibration, then it's possible that at certain frequencies, the intermittent break in the circuit could be synchronous with crank revs. So it might be connected when one of the outer cylinders comes to compression, but not when the other one does. Yeah, I know it sounds pretty unlikely, but stranger things have happened.
